I have a question about a newly rebuilt second story sun porch. It is now about 20 degrees here in Kentucky and I have noticed that my second story sun porch is sweating. The room contains 10 large casement windows that are sweating. The room is not heated nor air conditioned. The room was rebuilt with 2×4 walls with miraflex insulation. The exterior is constructed of 1/2″ plywood sheating with Tyvek housewrap followed by 1/2″ MDO plywood with redwood trim. The floor is insulated with R30 insulation with 3/4″ TG plywood followed by 1/2″ durock and ceramic tile. This floor was built up considerably over the old sloping floor therefore there is considerable air space underneath. The ceiling is also insulated with R30 insulation with considerable airspace between the ceiling and the porch roof. One wall of the porch is the back of my brick house. Did I over-insulate or build the room too tight without enough ventilation?
Thanks,
Stan
stan... sounds like a lot of moisture migrating from the ground up thru the brick wall...
try temporarily covering the brick with polysheet and see what happens..
you can alos take a humidity reading with a sling psychrometer
The thing that's certain is that there is moisture in the room air. Where from is uncertain in my mind. It could be the bricks wicking but might be from side or above too, or somehow getting into room from inside house. I'm interested what is the access from house and how used..
true... but a RH reading would be interestingMike Smith Rhode Island : Design / Build / Repair / Restore
That too.
Thank you for your theories. I might add that this is a 90+ year old house without insulation in the brick walls. This porch begins approximately 16 ft above ground. The mortar is in good shape, the foundation is comprised of 18" thick stone walls, and the ground area beneath the porch is a screened in concrete patio. I wouldn't think that there is excessive moisture in the ground around the foundation in this area. The access to the sunporch is a french door in one of the bedrooms upstairs. The roof over the sunporch is tar and gravel and does not leak. The ceiling in the sunroom is dry. I hope that this clarifies the conditions surrounding this area.
Thanks,
Stan
stan..... the ground under the stone foundation doesn't have to be excessively wet..
the bricks act as an almost perfect wick... try the poly taped to the porch brick wall and see if you have condensation on the back of it.... dollars to donuts , that's the source of your moistureMike Smith Rhode Island : Design / Build / Repair / Restore
I like the brick wall hypothesis, however I propose that it is coming from above the porch. Check for a failure in the roofing near the roof edge and brick wall. Also confirm you don't have any damaged bricks above and the mortar joints are sound. Maybe it's time to repoint.
Plants, Too many Plants........... :-)
Bob
Pro-Dek:
My wife does keep quite a few plants in the sunroom. When it turns cold, she moves all of the outdoor plants to the sunroom.
Thanks,
Stan
Therre you go. Prodek wins! Plants transpire lots of water..
