I’m building an 8’x8′ swim raft for the kids using sealed 30 gallon plastic barrels for flotation. I would like some ideas how to fasten the barrels to the platform. The deck will be framed with 2″x6″ and the decking 3/4 plywood – all treated. I’ve considered metal banding that goes around the barrels and fastens to the frame but am concerned with rust. Galvanized cables may be another option but think that if they loosen the wave action on the lake may wear the cables through the barrels. Maybe 1″ or 2″ flat nylon tie down straps with a ratchet? Any ideas?
![](https://images.finehomebuilding.com/app/uploads/2024/04/29113159/BUILDING-SCIENCE-SYMPOSIUM-1-Large-thumb-16x9.jpeg)
Check out the lineup for the 2024 Building Science Symposium featuring experts like Steve Baczek, Dr. Joe Lstiburek, and more.
Go to yor local Fire Department and find out where they discard there spent fire hose.It works great for straps and if you loop it around the perimeter of your raft it makes a soft edge for your ski boat to rub against.
I'm building an 8'x8' swim raft for the kids using sealed 30 gallon plastic barrels for flotation. I would like some ideas how to fasten the barrels to the platform. The deck will be framed with 2"x6" and the decking 3/4 plywood - all treated. I've considered metal banding that goes around the barrels and fastens to the frame but am concerned with rust. Galvanized cables may be another option but think that if they loosen the wave action on the lake may wear the cables through the barrels. Maybe 1" or 2" flat nylon tie down straps with a ratchet? Any ideas?
