Switching a GFCI Outlet
MikeMicalizzi | Posted in General Discussion on October 25, 2011 10:20am
Can you switch a GFCI outlet? I’ve seen this on rare occasion and wondered if it was acceptable. I’m guessing not.
  1. DanH | Oct 25, 2011 10:40pm | #1
    There should be no safety hazard in switching a GFCI outlet.  There would be a slight increase in the likelihood of false trips, but probably not a significant issue with modern units.
    I can't say, though, that there isn't some subparagraph in the code that prohibits switching them.
  2. gfretwell | Oct 26, 2011 12:20pm | #2
    No problem at all. The GFCI on my boat lift is switched from the house and I never had a problem with it.
    It is very common to have the outlet for GFCI pool pumps to be on a timer.
