switching relay; problems with pumps
I have a taco 2 zone switching relay. 2 thermostats are supposed to power 2 separate pumps. my problem is that when either one (thermostats) calls for heat both of the pumps respond. where did I go wrong. thanks
You miswired it.
do you have a picture of the wiring?
I'd first point out that you need two relays to control two pumps with two thermostats.
A more detailed description of your setup would be helpful.
I read it as he has a 2 zone relay.... DPDT/CO or similar or even a NO/NC/NO contactor....
but like ya said... more info please...
You mean an interlocking relay, so they don't both come on at the same time?
What is wanted is not the will to believe, but the will to find out, which is the exact opposite. --Bertrand Russell
It is more than a simple relay.http://www.taco-hvac.com/uploads/FileLibrary/SR502(102-082).pdf
http://www.taco-hvac.com/en/products/Switching%20Relays/track_file.html?file_to_download_id=17062http://www.blueridgecompany.com/radiant/hydronic/427My guess is that it is miss wired..
Are you using electronic stats?
Is it a SR502?
Did you the jumper in the wrong place?
