synthetic stucco over plywood
Rickter | Posted in Construction Techniques on June 10, 2003 10:58am
Does anyone know of or have any experience with a synthetic stucco type coating that can go directly over plywood? I am somewhat familiar with Grailcoat,(been to their website)but would be interested in any other products and comments.
Rick
  1. FastEddie1 | Jun 11, 2003 12:15am | #1
    Check out teifs.com or 800-358-4785.  Their installation manual says (paraphrased): Teifs shall be applied to the following Substrates...min 1/2" 4-ply APA exposure 1 grade c-d or better plywood with the better side in contact with the teifs adhesive.
    Do it right, or do it twice.
  2. Piffin | Jun 11, 2003 02:59am | #2
    I used some called Comproco, I think it was, thirteen years ago. That stuff wears well, It's still on the handles of my trowels and floats!
    Dinosaur | Jun 11, 2003 04:44am | #3
    I use a product called ISO-TEX, manufactured by a company called MF Paints, in Laval, Quebec. I don't have the phone number or web site handy off-hand.
    First time I used it I went straight on over new plywood, as directed, in a new house. First winter, it peeled in large areas and I had a rare call back in the spring. We scraped the peeled areas and then put on an alkyd primer made by the same company, then re-applied. No problem since then on that house.
    Now that I've learned the hard way, I always prime the plywood and I get excellent results.
    This product is just barely thick enough to be applied with a float, if you like; contrarily it's also just barely thin enough to be applied with a roller. I find the float method faster, plus I've got more control of the finished texture. But wear a coverall and a hat!!
    I'll try to find contact info for you for the manufacturer and will re-post if I do.
    Dinosaur
