I m a framing carpenter who has bought a house (the horror!) and I find myself spending a wonderful saturday NOT surfing, but installing BAmboo floor. The question for the experts present (god bless you all) is what to do with a floor which is put down “perp” to the hallway. Should the T & G meet under the door, outside the door? And is it normal to use a biscut joiner and super small biscotti to join butts in the field. And, furthermore. will the addition of glue cause any problems in the bicuit joints? Looking forward to a wonderful Sunday of NOT surfing…HD
Keeping HVAC systems within the conditioned enclosure can be tough without a basement; one option is to use plenum trusses for the roof, which offer a space for equipment and ductwork.
One rule of thumb, is to have your floor transition centered under the door when the door is closed. Or if it is an open passage way (no door) then centered in the opening.
I usually avoid this dilema and install a traditional threshold at the opening, which runs parallel with the opening and is maybe 2-4" wider than the opening. If your material is not sufficiently wide for the threshold, use two pieces (3 etc) centering on the opening.
I use a slotting bit with my router, 1/4" is about right size for most strip floor tongues. If need be I will slott both ends and use milled splines slide into the slots. I do not bother nor usualy recommend gluing the joints.
You can always lay floor at night. Surfs Up
I like the traditional approach in general and took a walk down to where this problem lurks. I see that the door will cover this joint, and thank you for your input. Sound and workable. Except that the nextdoor neighbor is my boss and he usually goes to sleep early. The compressor/chopsaw/nailgun/bitching & moaning noise will do me wrong come Monday morning. HD
What!, you bought a nouse next to YOUR boss. You will never a have a day off. That's almost like being married to your work
I usually install a piece of floor board purpendicular (parallel to
the door) for the flooring to tie into and give a good look.
