table saw choices need help spending $
toolpouchguy | Posted in Tools for Home Building on March 21, 2009 02:33am
second 2708 just crapped out what table saw should i buy. have and old rousseau stand and now no saw to fit it sigh……
still have the 2708 and the rosseau stand but… i am not to fond of the saw plastic bevel gear strips easily
plastic ugh…
I am looking for a nice saw that will hold up well with a crew of guys using it .trim, siding, framing ,it would get used everyday .
#160;<!—-><!—-> <!—->
  1. Waters | Mar 21, 2009 02:46am | #1
    I'm on my second bosch with gravity rise stand.
    I sold the last one to a guy I worked for.
    I had a dewalt too, and the rack and pinion fence was nice... but the motor in the bosch is way smoother and has soft start.
  2. andybuildz | Mar 21, 2009 03:00am | #2
    Was gonna get the Bosch but when I saw the Ridgid on sale last Black Friday for $299 I couldn't pass it up. Super easy to set up and not bad getting in and out of my van. I like how it stands striaght up when closed. Balances really well propped up in closed/folded up position. The fence works real well. Plenty of power although a little noisy when first turned on...big deal. Glad there's a place to wrap the cord when done. For the $299 I couldn't be happier really.
    http://www.ramdass.org
  3. Piffin | Mar 21, 2009 03:26am | #3
    For a rough crew, I'd go with the Bosch or the Rigid
    1. andybuildz | Mar 21, 2009 04:55am | #4
      what about a dainty crew : )~
      The one below is for the rough crew...lol
      Edited 3/20/2009 9:57 pm ET by andybuildz
      1. chairmon | Mar 21, 2009 07:30am | #5
        Sense you are shelling the drop in saws for your Rousseau buy a $99.00 Robbi and use a 7 1/4 marathon as the blade. Also consider picking up a sawhorse like this http://www.amazon.com/Crawford-Adjustable-25-Inch-34-Inch-Sawhorse/dp/B0009WG5ZI/ref=sr_1_9?ie=UTF8&s=hiqid=1237609378&sr=8-9 cut off one end. weld on a "L" to the cutoff to hang on the front 2x2 rail (same one that you attach your fence) to use as an in feed rail. also consider picking up another out feed table and modifying your left side rail to fit it. For the price of a better saw you can buy a cheep saw and mount a blade it can handle & mod your Rousseau to rip or cross cut 4x8' easy by your self. The system works well.
        Thanks Craig
        1. toolpouchguy | Mar 21, 2009 12:34pm | #6
          I rip alot of mdf one guy who works with us has a cheap saw breaker constantly blows .could just be the crapman saw .
          what i need is another 2708 makita tough as a brick if anyone has a motor send it my way .
