table saw wiring- too small?
edwardh1 | Posted in Tools for Home Building on October 24, 2012 04:08am
I have a 2000 year powermatic table saw. it has a 1 1/2 hp single phase 115 volt motor . the motor nameplate says it draws  15 amps. when I look up a 1 1/2 hp single phase mtr on internet it says it draws 20 amps.
the wire from the motor to the saw switch (3 ft) , and from the switch to the plug (4 ft cord ) that came with the saw is 14 gage.
is this wire too small?
  1. remzeppelin | Nov 25, 2012 03:16am | #1
    As mentioned 14ga should suffice.
    If the wire is original from p-matic, I'm sure they know what they're doing and build to nameplate specs.
    I would be more concerned with vibration and it's effect on connections.
    Tight/clean connections make all the difference in the world
    If your wire is to small it will also get quite warm to the touch and your saw would labor to start.
    1. DanH | Nov 25, 2012 09:01am | #2
      If the saw seems just a hair underpowered and sluggish you might see some slight benefit in replacing the wire.  But keep in mind that the wire in the motor itself is probably smaller.
      You do want to avoid long extensioin cords, even if they are #12, and make sure that the circuit you're using is a 20A with #12 wire.
    2. edwardh1 | Nov 25, 2012 02:31pm | #3
      thanks
      no warm or hot wires
      must be ok? feed to the wall plug is 12ga, then biggest ext cord I could find, also 12 ga but only rated at 15 I am told due to the plugs
      1. DanH | Nov 25, 2012 02:46pm | #4
        The thing with the plugs is an artificial, label-only limitation.  An official 20A plug has one prong twisted at right angles to the "normal" 15A orientation.  This will only plug into a 20A outlet, which is one of those outlets with the T-shaped prong opening.  In terms of actually handling the current the cord is fine, if it's #12.
Versatile Vise
