Tando Beach House vs Cedar Impressions Siding
houseofeternalperil | Posted in General Discussion on February 20, 2022 10:36am
Renovating exterior of my home. Small ranch. Trying to use mid to upper tier components. Used Anderson Woodwright windows which I thought were top quality but was disappointed in construction quality. Trying to avoid making a mistake with siding and trim. For siding I am considering Tando Beach House or Certainteed Cedar Impressions.
Can anyone provide a professional perspective on the Tando? I am a little alarmed at the stories of Certainteed failures as well as reports of less than adequate response regarding failure/warping, etc. I have not been able to find any negative experiences with the Tando product which leads me to 2 possible conclusions. 1-The product is amazing or 2-They have hired web cleaners to remove negative experiences. I am concerned with the durability of the “print” on the tando siding regarding its durability and fade resistance as opposed to the more “homogenous” coloring of the Certainteed where the color is consistent through the siding panel. I am primarily looking for responses from homeowners who have either product or better yet installers who have used one or both products.
Finally, I am struggling between using Boral or Azek for the trim. The Boral seems more fragile than the Azek. I want to avoid J-channel to the extent possible and will be using either factory grooved trim or routing trim out to receive the siding. Interested in anyone’s perspective on these products. Thanks in advance for your replies!
  1. edwardh1 | Feb 20, 2022 11:13am | #1
    what's wrong with Hardie plank cedar imprint?
  2. houseofeternalperil | Feb 20, 2022 12:09pm | #2
    Nothing. Fine product. But in the research I did some quality issues appeared, and I was concerned about moisture getting behind it and when the sun comes out being driven into the wall. Seems like that would be less of an issue with vinyl siding.
    1. capehome | May 30, 2023 09:09pm | #3
      did you get a good answer to this question...i am trying to decide now
      1. bing0328 | May 30, 2023 10:15pm | #4
        I'm a big fan of Hardiboard. Installed in 2001 in Big Bear Lake, CA. Lots of snow.
        Painted when installed, still looks great. I installed and painted.
        1. capehome | May 30, 2023 11:42pm | #5
          thanks I like hardie board too but that is not an option at this point
          I am looking at the vinyl shakes and these 2 are the top contenders and cedar impressions is more expensive. I don't know if I will regret going with the beach house and of course the published pics look perfect !!
          1. stevemeltzer | Mar 26, 2025 10:06am | #7
            Hi Capehome. We are looking at both the Cedar Impressions and the Beach House Shake (Pacifica). Which way did you go? Was there much of a price difference between the two?
    joshbrennecke | Jun 01, 2023 01:25pm | #6
    I, too, am considering Tando Beach House Shake siding as an accent portion on my house. What did you end up going with, and how did it turn out? Any insights, learnings, regrets?
FHB Podcast Segment: Sometimes Spray Foam Makes Sense, Sometimes It Doesn't
Spray foam is a great invention, but it's not always necessary.
