We may put a tankless unit in. What is the BTU of a 240volt 12 kilowatt tankless water heater? The electician said with 100 amp service we should limit the unit to this size.
41,000 btu's.
Unless this is just for washing hands and you are in FL I doubt that is enough.
the manufactures will have charts showing temp rise with flow.
and what kind of electrical loads do you have? sq ft of house, electric stove? dryer? ac?
Hello Bill:
Later I realized those numbers were for an electric model. If we go the tankless route, it will be a gas model. For my 1200 s.f. with two full baths and one teen, it looks like a 140000 BTU model is needed.
Mike
"For my 1200 s.f. with two full baths and one teen, it looks like a 140000 BTU model is needed."Don't forget to check whether your gas line is big enough. Most residential gas water heaters are piped with 1/2". If yours is 1/2" your water heater would have to be within 15' of the meter with no elbows or tees to get enough gas volume to run your 140,000BTU heater. If it is 3/4", the meter could be 40' away.http://www.metrokc.gov/health/plumbing/gaspiping.htmBruceT
Edited 8/25/2008 3:03 am by brucet9
Thanks for the tips. I will keep it in mind when we do the water heater.
Mike
Electric tankless rarely makes sense. Even gas-fired tankless is iffy -- some people swear by them but others swear at them, and there's little evidence of energy savings, etc.
Thanks Dan H, I realized later that the numbers were for an electric one. I think we will stay with a tank model.
Mike
I'm betting the savings isn't in the direct energy consumption of tanked vs tankless, but I bet if I place point of use tankless systems in the kitchen and master bath I could something on water.
I bet I lose a gallon of water each time I turn a faucet or shower on. Imagine ten times a day for about 3500 gallons. Ok, so maybe not even that is much of a cost savings, but how about my time and impatience. :)
There are other (cheaper, simpler) ways to address that problem.
Too much sanity may be madness. And maddest of all, to see life as it is and not as it should be! --Miguel de Cervantes
"I bet I lose a gallon of water each time I turn a faucet or shower on."You're probably right. 24.5 ft of 1/2" pipe contains 1 gal water.BruceT
At 120K BTU input you get 4 gal/min of hot water from a gas tankless. Electric is more efficient but I'd say 80K BTU (24 kW) is the minimum for a normal house. If you have 240V/100A service 24 kW pretty much maxes it out.
Thanks for the advice.
Mike
I too had always been told, by everyone in "The Know" the only time you go tankless is with LP or natural gas. Elec. will end up costing you money.
"I too had always been told, by everyone in "The Know" the only time you go tankless is with LP or natural gas. Elec. will end up costing you money."People REALY IN THE KNOW know that the only way compare electric to gas is based on THAT PERSONS SPECIFIC RATES.With one exception if electric is more expensive than gas for a tank type WH then is is more expensive than gas for a tankless.And if electricity is cheaper than gas for a tank style tank it will be cheaper for a tankless.The one exception is that in some areas late night hours have some special very cheap rates. To use those one would need larger (depending on the number and pattern of use of HW)electric storage tanks and a time clock..
But it's generally true that the "infrastructure" upgrade cost for retrofitting a gas tankless is significantly less than for an electric tankless. Gas unit may (or may not) require larger pipe and/or meter, electric unit will usually require a new electric service.
Either can be rather expensive to install. Can require lots of expensive SS vent pipe. And gas pipes replacement can be a lot hard to snake than electric..
Edited 8/25/2008 9:07 am by BillHartmann
Thanks for the reassurance.
Mike
