Tankless water heaters
timc | Posted in General Discussion on January 16, 2006 04:30am
I have had a Takagi TK2 instantaneous water heater mounted on the outside of my house for about 18 months and have been pretty pleased with it. However, now that gas prices are increasing I decided to set the temp down to 112 instead of 120. When I opened the unit and checked the manual it has different settings depending on whether the unit is natural gas or LP and inside or outside. Mine was set at 120 for a natural gas unit inside but it is outside. Does anyone know what difference it makes if the setting is inside as opposed to outside? How would this affect efficiency and gas usage?
thanks
    razzman | Jan 17, 2006 06:47am | #1
    Greetings tim,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
    Perhaps it will catch someones attention that can help you with advice.
    Cheers
    'Nemo me impune lacesset'
    razzman | Jan 25, 2006 08:54pm | #2
    Let's run this thru once more.
    If no response you might want to repost your question over on the JLC forum.
    http://www.jlconline.com/cgi-bin/jlconline.storefront
    Cheers
    1. timc | Jan 26, 2006 03:13pm | #3
      I ended up calling the manufacturer, thanks anyway
Fast, Accurate Wall Framing
  • Smarter Stop Block
  • Square Walls Solo
