Tankless WH in attic
mwgaines | Posted in Energy, Heating & Insulation on April 16, 2007 01:49am
As part of my major remodel, I’m planning to convert to a gas-fired, tankless water heater, and I’m thinking of placing the unit in the attic. Any code issues or other reasons why this might be a bad idea?
New knowledge is priceless.
Used knowledge is even more valuable.
  1. plumbbill | Apr 16, 2007 03:40am | #1
    Access & proximity to combustibles is the only thing that comes to my mind.
    “When politicians and journalists declare that the science of global warming is settled, they show a regrettable ignorance about how science works.” Nigel Calder,  editor of New Scientist
  2. BillHoover | Apr 16, 2007 03:58am | #2
    When it leaks and all water heaters will eventually leak, it can cause extensive damage in an attic unless it has a very good drip pan with a drain that is kept clean of bugs, nests, etc.
    Bill
  3. IdahoDon | Apr 16, 2007 05:38am | #3
    Depending on your climate, there is also a freeze risk.  Many units have a freeze protection feature that keeps any water in the unit safe, but that doesn't apply to the pipes to and from the unit.
  4. davidmeiland | Apr 16, 2007 07:30am | #4
    I have a Takagi in the attic, with a rupture pan under it. I had to run gas and water up there, which wasn't a big deal. There's a nice short run of that really expensive stainless flue right thru the roof. Piece of cake. Since Takagi heaters make some noise it's actually a great place for it.
      InspectorDude | Apr 16, 2007 08:01am | #5
      Ditto to the aforementioned posts.  Tankless water heater is fine at the attic.  Drip/catch pan is "required."  Most frequent installation screw-up is not sizing the gas line properly.
