What is the recommended spacing for attaching plywood over XPS to a concrete slab with Tapcon screws. Do I need to screw around the perimeter of the plywood or the entire panel to the floor?
Thanks,
Rick
Thanks,
Rick
Follow these tips to prevent paint from drying too quickly.
Tapcons
I have done much the same on walls. Just srewing the edges can pull them down to much and cause the field to raise up, out of plane. I use a 9' and 6' staight edge to check the flatness as i go along and add tapcons as needed in the field. I also use PL 300 behind the plywood to help minimize the number of tapcons.
