tape for polyethylene vapor barrier
GC | Posted in Construction Techniques on July 3, 2005 07:24am
I need to tape the seams of the 6 mil black polyethylene I’ll be installing for a crawl space vapor barrier.  What tape is used for a permanent connection?
I’m already familiar with Tu-Tuff and other high performance membranes; all these are not an option for this job.
Thanks in advance.
  1. piko | Jul 03, 2005 08:37am | #1
    Around here we just lap the edges a foot  and stick a couple of rocks on top....
    I've found the red tape used for Tyvek works well, if you want to go that way.
    cheers
    ***I'm a contractor - but I'm trying to go straight!***
  2. suntoad | Jul 03, 2005 03:44pm | #2
    Just use a good, messy acoustic caulk and lap the edges.
    rjw | Jul 03, 2005 04:05pm | #3
    Another vote for just overlapping, althouygh I go 18".
    If you're really determined to tape the seams, better to spend the $ for obsessive compulsive disorder treatment <G,D&R>
    Sojourners: Christians for Justice and Peace
    1. GC | Jul 03, 2005 07:28pm | #4
      Original idea was to use a machine for fusion welding the seams.  Hmm... I thought I'd licked the OCD when the therapist suggested the tape idea.  :-)
      Thanks for the suggestions so far.  Does anyone have any additional experience with tape for this application?
      1. edwardh1 | Jul 03, 2005 10:47pm | #5
        you need to have the final seams checked to code, per the ASTM standard by a certified seam inspector.You do want to do it right don't you?
          BillHartmann | Jul 04, 2005 02:58am | #6
          "per the ASTM standard by a certified seam inspector.per the ASTM standard by a certified seam inspector."Those must be the people that leave the notes "Inspected by #7" in the packages of Fruit of Loam.
          1. DanH | Jul 05, 2005 07:21pm | #7
            The obvious solution is to get yourself ASTM certified. Then you can tell the ladies that you're a certified seam inspector and you need to inspect the seams on their undies.
  4. Tracker | Jul 05, 2005 07:34pm | #8
    I'm in the process of the same job....bought the 6 mil yesterday and considered duct tape for the job...but I had to buy enough plastic to cover an acre so I knew I would have enough to over lap 3 or 4 feet...and go with the rock idea
    S
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
