Taping Crawlspace Vapor Barriers
| Posted in Construction Techniques on March 11, 2002 08:51am
I plan to install poly plastic sheeting in a crawlspace that is below grade. There are a dozen places on the web that say to “tape the seams” but none that say what tape to use. Called the manufacturer and he didn’t have any suggestions either. Does anyone know the answer. Thanks.
  1. LFred | Mar 08, 2002 02:52am | #1
    Tuck tape.
    1. Tripper | Mar 08, 2002 03:32am | #2
      *As far as I know, vapor barriers don't need to be taped, only infiltration(air barriers). Just overlap the seams. But if this doesn't fly with you, to answer your question, a lot of guys use housewrap tape which you can buy at Home Depot or Menards in the insulation department. Good luck.
      1. FredL | Mar 08, 2002 06:00am | #3
        *Dear Rob,Regular poly doesn't tape together well at all. The last time I used it, we laid a fat bead of butyl caulk between the laps.Now I use Tu-Tuf (see efi.org) for ground cover. It seals very well with Tyvek tape and others like it.Regards, Fred
        1. David_Mason | Mar 09, 2002 06:34am | #4
          *I use that red Tyvek tape also , and butyl "Black Death" caulk at every seam.Dave
          1. Hausdok_ | Mar 11, 2002 08:51pm | #5
            *Hi,Expanding polyurethane foam from a can, such as "Great Stuff", works well to seal the sheets together at overlaps and to anchor the barrier to the walls of the foundation above the footings.ONE TEAM - ONE FIGHT!!!Mike O'HandleyBungalow Rescue, Seattle
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
  • A Postwar Comeback
  • Natural Simplicity
