Tapping into a run of recessed can lights
merlvern | Posted in Construction Techniques on April 12, 2011 02:20am
howdy all, i’m brain cramping on this one …..i think!
i have a run of can lights (2) and switch that goes sequentially:
power (from circuit breaker) – can light – can light – switch
can i tap off the 2nd can to run a dead-end set of two more cans….in other words, they wont be “in line” with the others on the circuit, but off to the side forming one leg of a “T” shape?
thanks in advance, i appreciate it.
john
  1. mike261 | Apr 12, 2011 03:19pm | #1
    yup.
    1. merlvern | Apr 12, 2011 03:53pm | #2
      thanks, i feel silly, don't know why the thought of that made me question myself. :)
  2. gfretwell | Apr 12, 2011 04:12pm | #3
    The problem might be box size. There may not be enough room in the box on the can. If you have access from the top you can add a J box
    1. merlvern | Apr 12, 2011 04:19pm | #4
      thank you,
      plenty of room, and the joist bays are open!
  3. DanH | Apr 12, 2011 08:06pm | #5
    You need to make your connection to the same two wires that are feeding the light you tap off of.  There may be a 3 or even 4-wire cable running through the box., but ignore the other wires.
