Technique for cutting skylight caulking?
geoffhazel | Posted in Construction Techniques on April 23, 2004 01:26am
Situation: customer has a skylight, 2’x 4′, fixed, on a 2×4 curb. It’s been caulked to the wood, and screwed on the flanges. There’s about an inch of space from the wood/skylight joint to the glass. The skylight has a white plastic flange that’s the part that’s glued to the wood. The screws on the outside are easy, but the caulk is a head scratcher.
I need to remove the skylight without hurting it. I wonder what the best way to cut through that caulk is? It was squashed flat upon installation, there’s not much gap to try to pull a knife or some other cutting tool in. If it was all wood, I’d be thinking Sawzall but it ain’t.
Ideas? Please?
  1. Piffin | Apr 23, 2004 01:40am | #1
    It sounds like a disposable unit to me anyway, so don't expect too much.
    Most caulks are thermoplastic. You can use a heat gun and slide in a flexable putty knife
    IMERC | Apr 23, 2004 02:32am | #2
    Plastic flange and UV on a skylight.... Consider it history...
    Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming....
                                            WOW!!!   What a Ride!
    1. geoffhazel | Apr 23, 2004 06:45am | #3
      I didn't do a great job of describing the skylight.  It's a metal frame, double layer glass skylight, with a plastic flange INSIDE the frame.   It's worth saving, it just needs to be re-installed with more slope.
        IMERC | Apr 23, 2004 09:10am | #4
        Is the plastic frame you are trying to save or having trouble getting the sky light off of the roof? The sky light self curbed?Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming....                                        WOW!!!   What a Ride!
      2. Piffin | Apr 23, 2004 01:40pm | #5
        Still, the only skylights I have seen that meet that description and mount in sealant on a job made curb, are of lower quality and are far less likely to survive the work.. If it isn't leaking, and you only want a cosmetic change, I wouldn't touch it, myself.
  3. OneofmanyBobs | Apr 23, 2004 02:06pm | #6
    One of the gizmos you use to install windshields?  Made to cut the sealant around the old windshield.  Has a right-angle blade on a substantial handle and a second handle with a rope so you can really pull on it.  Handle may be long enough to get down to the flange.  Or, make something like that with a dowel and a blade.
  4. andybuildz | Apr 23, 2004 02:55pm | #7
    what the piffmiester said.......heat gun will melt it nicely
    My life is my passion!
