Temporary Caulk for Sink
Scott | Posted in General Discussion on March 8, 2006 07:22am
Any suggestions for a temporary material to caulk around a bathroom sink? I’ll be pulling it out in a few months when I install the ‘real’ counter top. If I use silicone is there a solvent that will cut it?
Thanks,
Scott.
Always remember those first immortal words that Adam said to Eve, “You’d better stand back, I don’t know how big this thing’s going to get.â€
Edited 3/8/2006 11:23 am ET by Scott
  1. MikeHennessy | Mar 08, 2006 07:35pm | #1
    Yep. There is a silicone caulk solvent. I get mine at the local HW store in the paint dept. (Don't remember the brand name, but it's in an orange squeeze bottle.) You have to let it sit for a bit, but it does a pretty good job. Just don't caulk under the rim where you can't get at it to cut the sink loose.
    Mike Hennessy
    Pittsburgh, PA
  2. DougU | Mar 08, 2006 07:39pm | #2
    If its temporary then just use latex caulk, that'll last until your ready to pull it up.
    I'd hesitate to use silicone temporarily, to much of a pain in the azz to get up.
  3. atrident | Mar 08, 2006 07:41pm | #3
      There is some removable caulk used for winterizing. It peels off when you dont need it. Should work fine.
  4. BobS | Mar 08, 2006 07:44pm | #4
    Liquid nails makes WindJammer and Dap makes Peel N Seal. Both of these are temporary weatherstripping type caulking that you can, allegedly just peel off when summer comes (or in your case, when your new coutertop comes). Windjammer says its waterproof though I'm not sure they mean for it to be used in a bathroom. For a few months though, you might try it.
  5. philarenewal | Mar 09, 2006 03:20am | #5
    How about old fashioned plumbers putty.  It will do what you need, and, unless you're working with a porous stone (like marble or its cousin limestone), no trouble to remove.
    "A job well done is its own reward.  Now would you prefer to make the final payment by cash, check or Master Card?"
  6. DanH | Mar 09, 2006 04:00am | #6
    Yeah, either use one of the temporary caulks designed for winterizing, or use plumber's putty. The caulk removers work to a degree, but not well enough that you can count on them in this situation.
    happy?
    1. Scott | Mar 09, 2006 04:49am | #7
      Thanks all. Those are good ideas. I'll look around for one of these products.
      Scott.Always remember those first immortal words that Adam said to Eve, “You’d better stand back, I don’t know how big this thing’s going to get.”
