How does one attach a picture to this message?
I click on the ‘attach files’ at the bottom, but nothing happens.
Click on 'attach files' and a window should open. Use 'browse' to find the file on your computer. Click 'upload' and wait quite a while, as nothing appears to be happening. Wait long enough and the window will change and will show your file name. Click 'done' and then click 'post' to post your message with the attachment.
attach..
loading window opens
hit browse...
select file or pic to load..
hit up load...
repeat as you like..
hit done when yur done...
remember there's a bunch of dial uppers here..
If nothing happens when you click on "attach files", the most likely reason is that you have a popup blocker running. Some people have reported having more than one popup blocker running without even realizing it, so if turning off the one you know about doesn't work, keep digging.
Of course, all this will probably change tomorrow with the new registration.
Edited 7/25/2005 5:51 am ET by Uncle Dunc
