I am trying to understand the basic idea behind filling up the shower pan membrane with water and testing it. I know it is too test if there is a leak, but how could you tell? Unless there is a major hole in the liner, it would be a slow leak, right? Would you even see it in 4 hours? Or is it to test the silicone around the drain as well?
Listeners write in about saving frogs, attic ductwork, lime wash, and energy ratings for real estate.
The code (UPC) says you fill the pan with water up to the threshold level and leave it filled for 24 hours.
