Textured ceiling and skim coating
frodo066 | Posted in General Discussion on March 14, 2019 01:40pm
I have a textured (not popcorn) ceiling that I wish to smooth over and paint. Looking to make the ceiling look like I had simply sheet rocked the ceiling and painted it. I believe that removing the textured ceiling by scraping would be messy and time consuming. I am wondering if I can simply skim coat the ceiling to make it smooth and then paint it. I believe that there should be a “prep” solution applied to the textured ceiling first and allowed to dry before skim coating. My concern is that the skim coat material will not adhere for a long time and start to separate from the underlying substrate.  My questions are as follows:
   1. Can I use a skim coat for this purpose?
   2. Is there a special type of skim coating product?
   3. Is there a pre skim coat prep to be applied?
Thank you for your help.
Steve
  1. calvin | Mar 14, 2019 04:38pm | #1
    Steve, your concerns are correct, don’t do it.
    Even if you tried and did knock most of it off, the remainder would dislodge one pc at a time and each skim with your trowel would drag “hitchhikers” across the surface.
    Wet it down with a pump sprayer, scrape off onto your head and visqueen on the floor is one way.
    Rent or buy an industrial drywall disc sander w/vac and have at it is another.
    Best of luck
    Edit: sorry, somehow I thought I was replying to a question ABOUT a popcorn ceiling. I see now in your post “not popcorn”. Asleep, drunk or blind.
      frodo066 | Mar 15, 2019 11:37am | #4
      Thank you very much for your input. I was wondering if this was going to be a problem.
  2. florida | Mar 15, 2019 08:04am | #2
    We've done this many times. No need to do any prep unless the ceiling is in bad shape. We go over it with a 6" drywall knife to knock off any loose stuff or rough point. We take a gallon out of a 5-gallon bucket of joint compound then add water and mix with a mixing paddle. We want to get it to a consistency that allows us to roll it on the ceiling with a heavy paint roller cover. It's a 2 man job, one guy rolling and the other troweling. We use either an 18" trowel or, better yet, a squeegee trowel that can be used from the floor. Using the 18" trowels makes it easy to get it flat.
      frodo066 | Mar 15, 2019 11:40am | #5
      This is my son's home and I will send him your approach. Sounds like there is a learning curve to this but I'll see if he wants me or someone else to help him. Regardless, I thank you for your suggestion and time putting your thoughts together and forwarding them to me.
      1. ptchapman | Mar 15, 2019 06:09pm | #6
        Keep us posted on the progress, I'll be tackling the same project in the next couple of months...every time I look up all I can see is an impending dust cloud.
        1. florida | Mar 17, 2019 01:00pm | #9
          No dust at all. You aren't removing anything unless you have popcorn and that requires an entirely different answer.
      2. florida | Mar 16, 2019 08:43pm | #8
        It's really pretty easy especially if you use the magic trowel. The first job we ever did this way turned out really nice.
  3. calvin | Mar 15, 2019 08:15am | #3
    Flo,
    I’m glad somebody figured this out!
  4. user-7139738 | Mar 16, 2019 04:49pm | #7
    Do you need to worry about Asbestos? Any textured ceiling applied prior to 1980, should be checked for asbestos before you remove it.
