T&G Flooring Install – Nails or Staples?
GSPrice | Posted in Construction Techniques on June 20, 2007 03:36am
I’m about to re-install some 100 year old heart pine flooring after replacement of the subfloor.  It’s traditional 3/4″ tounge and groove.  What is the preferred way of installation, with nails or staples?  I’ll be buying/borrowing/renting a pneumatic nailer, and I’m not sure which method is best.
Also, what length fastener should be used?  It’s going down over 7/8″ Advantech plywood.
Any advice would be appreciated.
Thanks,
GSPrice
  1. FastEddie | Jun 20, 2007 05:21pm | #1
    Personally, I think a floor nailer is correct for 3/4" material, and a floor stapler works well for thinner laminates.  But, many disagree with me, saying that a stapler will work just as well.  I think HD rents a nailer, be sure to get the pneumatic version, and their nails are 2-1/4" I think.  And some folks call them cleats, but it takes a special knid to fit the gun so there's no chance of using the wrong style.
    Edited 6/20/2007 10:22 am ET by FastEddie
    MrSQL | Jun 24, 2007 06:40am | #2
    For my own house I chose the stapler.  Believe me it will hold well.  Staples are much cheaper then nails.  If the stuff is over 5" wide consider adding a couple of plugs across hte width will help
    Roger <><
  3. RalphWicklund | Jun 24, 2007 06:53am | #3
    I use the Bostitch MIIIFS. Takes 2 inch staples. You misfire with a light tap and it takes 2 men and a boy to pry out a staple that's only embedded 1/2".
  4. davidmeiland | Jun 24, 2007 10:40pm | #4
    This is your basic Ford/Chevy topic. Comes up every month or so, with nailers and staplers split about 50/50. Since your material doesn't come with manufacturer's instructions about fastening then I'd flip a coin.
  5. GRCourter | Jun 25, 2007 03:49pm | #5
    I have worked with a lot of Heart Pine, 100+years old and I have always ended up with the nails, a couple of time I had a sub with a floor stapler and they just did not work, kept bending one of the legs.
  6. BilWil | Jun 25, 2007 04:25pm | #6
    You'll get lots of opinions on this.  My take:  if the subfloor is new plywood, then either will be fine.  I've had to pull up floors with nails, cleats, T-nail, and saw tooth nails.  None are easy!!!  I always go to cleats when the subfloor is old yellow pine.  It seems I get fewer problems and fewer bent fasteners.  I happen to own both a Bostich stapler and a PowerNailer.
    1. GSPrice | Jun 25, 2007 06:54pm | #7
      Thanks everyone for the feedback.   I'll be going with the flooring cleats.
