I am considering paneling the cathedral ceiling in my townhouse with wood. I like the look of T&G and would like to do it in Aspen to match the other woodwork. Besides the expensive 3/4″ material what other materials have others had sucess with?
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
If you were looking for a higher grade wood than Aspen you might get by with a thinner product. A mill near me sells Aspen beaded 1x4 for cheap as there is not much market for 1x4 stock. It looks good installed but there usually is about 20% waste.
Thanks for your reply. Can you give me contact information?
DT
I am considering paneling the cathedral ceiling in my townhouse with wood. I like the look of T&G and would like to do it in Aspen to match the other woodwork. Besides the expensive 3/4" material what other materials have others had sucess with?
