TGI floor
JohnCujie | Posted in General Discussion on February 22, 2008 07:15am
I have built many floors with TGI’s, but never lived in one until now. My joist are way under spanned, and I have the problem I describe below with even the shortest span. 3/4″ subfloor, with hardie underlayment set in thinset 100% per specs, and then porcelain tile over most of the floor. I get a definite vibration in areas such as the kitchen sink, or bath where things can rattle. There is no grout cracking. At first I thought that the OSB was flexing a bit, my first OSB floor, so I put some blocking in one area between joist and that made no difference.
I remember reading that because the truss joist are so light that they cannot absorb vibration. Is this my problem? I am thinking of spraying the underside with foam insulation but don’t want to if that will not solve the problem. It’s just annoying, not critical. Nothing like a callback on your own house.
Any other solutions or problems I may have overlooked?
Thanks, John
  1. RobWes | Feb 22, 2008 08:12pm | #1
    I have a TGI floor system and love it. Widest run is 13' on a 35' span. These sit on triple 12" LVL's. One set of LVL's sits on a lally mid length at 21 feet and the other is supported by a load bearing wall about 8 feet long near the center. The design was right from GP. 12" TGI, 3/4 T&G covered by 1/2, the a pour of 1.5 gypcrete. Rock solid throughout. No tile crack to date.
  2. Geoffrey | Feb 22, 2008 11:49pm | #2
    John,  funny you should ask.....
    http://forums.taunton.com/tp-breaktime/messages?msg=21010.1
        Geoff
