Hello all,
I would like some advice on what the advantages and disadvantages are with regards to tankless water heaters. I have a Trainco Heatmaker Heat Maker (Mark II 130 BTU) unit which provides both heat, (baseboard, and radiant) and hot water.
The unit is 14-15 years old and runs on natural gas. I like the fact that I don’t need to have a seperate hot water heater and that it takes up a small amount of floor space in the basement. Is this still an efficent wat to provide heat and HW? What makes and models are available that are built by quality companies that can be serviced by local contractors/ plumbing and heating companies.
I know it’s a lot of info to ask for but I’m not sure how much time this unit has left.
KaiserRoo
Veritable tombs of discussion on tankless water heaters here in the past.
Use the 'advanced search' function and start reading!
Ditto what Waters said - There have been literally hundreds of discussions about them.
Efficient? Yes, reasonably. Are your radiant heat and potable water part of the same loop of water? That may be a problem. Do you have a heat exchanger for the radiant system?
Personally, I'm not a big fan of the 'tankless rage'. IMO they are being oversold as having BIG savings which generally is NOT the case. Everything has a place, in space, in time, though and they are great for many applications. You are already set up to have it, so it's a reasonable thing to use.
You may get many more years of service from your old system. Keep your eyes on the newest technology and buy when it dies ... no sooner.
As mentioned in the thread' there is a lot to look up
my 2cts. If you go gas you often cannot vent into the same furnace vents. Extra vents thru the roof can be very expensive. You need the space, going thru floor(s), closets, extra framing, drywall, paint.
Some have direct vents, again it depends on where the heater is located.
2. option: go electric.
Personally I would wait until they have really reliable products on the market. Some European units are good but if you don't have a service depot close by it spells trouble. Also some electrics within the units can be very expensive to replace. All your savings go out the window.
Here are 2 more cents:
Four years ago, I had a Bosch tankless installed. I am pretty happy with it, but for two things:
1. It is sometimes difficult to mix hot and cold in the middle range. If you turn the cold on enough to make the water merely warm, the hot shuts off entirely. I am not quite sure why it does this, but it was mentioned in the instruction booklet.
2. The unit starts via a hydrogenerator - water flows through it, a wheel spins, and it creates enough current to light the piezo electric starter. Trouble is, the generator intake screen clogs about once a year, so no hydro-generation, no spark, and no hot water. By now, I am practiced enough to get it up and running again in half an hour or less, but still...
I like tankless, but I don't think that I would buy this unit again.
Alex
Outside of a dog, a book is a man's best friend. Inside of a dog, it's too dark to read.
-Groucho Marx
I also have a Bosch unit. When installed I added a whole house filter from sears with the clear case. I am always amazed by how much crud in the water. The dirt collects on the outside of the filter where you can see it. I change it around 3-4 months.
The township opens the system every 6 months to "clean" the pipes but stirs up the junk by doing this. My filter is covered in little bits after this.
The water tastes much better with the filter in. I use the black ones from HD with the charcoal in them.
I love the never ending hot water as we all leave around the same time in the morning. With the old system we would run out. When I refill the hot tub I just run the hot water till I have enough.
I would get another.
I researched this a few years back.any tankless system, especially one like the Bosch, needs to have a water softner and a fine particle filter upstream.Even "city" water can be hard and dirty enough to cause the need for a frequent cleaning regimen..
"After the laws of Physics, everything else is opinion" -Neil deGrasse Tyson
If Pasta and Antipasta meet is it the end of the Universe???
