The advantage of closed cell foam insul.
44 degrees outside this morning, 68 degrees inside. NO heat on.
Some of these smart devices are more than a leak alarm—they can help you understand your water usage and diagnose plumbing problems.
same here, Roxul mineral wool installed properly, 1/10 the cost of foam in this area!
