The insulation monkey
| Posted in General Discussion on March 16, 2005 10:03am
For using blown cellulose insulation it the ceilings with a 4.5:12 pitch trussed roof above, what size openings is your insulator able to wiggle through so as to direct his hose?
My girder trusses out at my hip ends are only about 3 feet high.  Heel heights at truss bearing are about a foot.
I haven’t had one blown at this shallow a pitch before.
  1. csnow | Mar 16, 2005 11:45pm | #1
    You can reduce the hose down with PVC conduit.  As little a 1 inch diameter can work.
  2. MikeSmith | Mar 17, 2005 01:09am | #2
    gene.. 3 ' high at the plate ?... wow.. like the Sistene Chapel.
     that 's a lot of room for maneuvering.. get up there and set an example
  3. DanH | Mar 17, 2005 04:23pm | #3
    In a typical vanilla 4/12-roofed tract home, where the trusses basically end on the plate, insulators can still get the stuff in there OK (though properly attaching vent channels may be a challenge).
Old House Air-Sealing Basics
