them funny/ bent concrete nails …
JeffBuck | Posted in Tools for Home Building on September 18, 2007 03:47am
trying to buy some of the concrete nails I’ve seen somewhere along the lines …
not fluted … has a regular head …
and has a slight bend near the tip.
supposed to drill hole and tap it home.
gotta know the nsame before I start asking around.
what are they called and where’d ya find them?
and do they work as good as I’m hoping?
looking at a job where I’ll have to fasten furring to block/ ceramic block wall.
thinking they’ll be faster than tapcons.
Thanks,
    Buck Construction
 Artistry In Carpentry
     Pittsburgh Pa
  1. mike_maines | Sep 18, 2007 04:23am | #1
    Yeah, those things work great.
    I can't remember what they're called either.
      JeffBuck | Sep 18, 2007 05:40am | #2
      well at least I'm on the right track!
      Jeff    Buck Construction
           Pittsburgh Pa
    BillHartmann | Sep 18, 2007 06:02am | #3
    They are deformed "nails".
    But since it is not a point I am not sure if they are called nails or not.
    Google did not find then under Deformed concrete Nails/Achors/Pins.
      JeffBuck | Sep 18, 2007 06:32am | #8
      I "googled" the heck outta them on Yahoo and couldn't dig anything up.
           Pittsburgh Pa
        MarkH | Sep 18, 2007 06:54am | #10
        Rawl concrete spikes
        http://www.amazon.com/s/ref=nb_ss_hi/104-1083192-9002365?initialSearch=1&url=search-alias%3Dtools&field-keywords=Spike+Concrete+Anchor+&Go.x=7&Go.y=10
          JeffBuck | Sep 18, 2007 07:01am | #14
          even better ...
          amazon.
          I tried a search there too ...
          oh well ... now they can't escape.
          Thanks.
               Pittsburgh Pa
      2. Blacky | Sep 18, 2007 06:55am | #11
        deformed shank,
        on a sidenote, ya ever go to station square and rent them segways?
        what a blast haven't had that much fun in a while.
        take care
        Dan
        Edited 9/17/2007 11:56 pm ET by Blacky
          JeffBuck | Sep 18, 2007 06:59am | #12
          didn't know station sq had them!
          when U were there ...
          and turned around and looked up that big hillside ...
          that's my neighborhood!
          used to rent right on "Grandview Ave" ...
          now we live over the hill a bit and around the corner ...
          thanks for the tip!
          and if ya went down on the docks and had a beer ... that used to be my old work station ... worked the boats for a coupla yrs ... loved tending bar at the dock bar.
               Pittsburgh Pa
  3. donpapenburg | Sep 18, 2007 06:22am | #4
    I have seen them in catalogs , under concrete fastners . I don't recall the name either .  try granger , farmtec , or Mcmaster carr.
  4. RW | Sep 18, 2007 06:26am | #5
    splits?
    http://www.split-drive-anchor.com/
    Real trucks dont have sparkplugs
      JeffBuck | Sep 18, 2007 06:31am | #7
      no ...
      but might be close enough.
           Pittsburgh Pa
  5. RedfordHenry | Sep 18, 2007 06:27am | #6
    I've never tried it, but have seen somewhere along the line a "tip" to accomplish the same thing.  Drill a 3/16-1/4" pilot hole, insert a common steel nail, then drive another alongside it.  I guess the key factor is the malleablity of the steel nails.  In a hollow block wall (vs. solid concrete), will probably have to match the pilot holes and nails very carefully to avoid cracking the block.
      SamT | Sep 18, 2007 01:52pm | #15
      I've done it a few thousand times. 1/4" hole, two 16d GVC's, drive both at the same time.Takes a four foot pry bar to get 'em out, jumping on yer flat bar ain't gonna do it.SamT
  6. reinvent | Sep 18, 2007 06:52am | #9
    Found them. Do I get a milk bone?
    http://www.barnhillbolt.com/index.php?root=menu&level=&menu=873&catid=-1&custid=723825717
    http://www.barnhillbolt.com/specs/75-76.pdf
      JeffBuck | Sep 18, 2007 07:00am | #13
      Yes ...
      yes U do.
      Thanks.
           Pittsburgh Pa
  7. rnsykes | Sep 18, 2007 09:19pm | #16
    http://www.powers.com
    click on the mechanical fasteners link, and scroll down to the impact fasteners section.  They call them spikes, but I've always called them bent nails.
  8. CAGIV | Sep 18, 2007 09:35pm | #17
    Just call your yard/hardware supplier and describe them, yeah you might sound like an idiot for a moment, but you're ego will recover I promise.
    Team Logo
  9. ronbudgell | Sep 19, 2007 12:38am | #18
    Jeff,
    A hole a little bit bigger than a common nail and a piece or even two of tie wire. Tighter'n something I can't say here.
    Ron
  • A Postwar Comeback
