Thermostat Common wire
blakevw | Posted in Energy, Heating & Insulation on February 26, 2012 08:35am
I am trying to update all my thermostats to inculde a common wire to avoid relying on batteries.  the problem I have is that some of the thermostats are far from the furnace, or are multiple floors above the source.
Does anyone know if a common wire can be jumped from a 120 circuit if run through a transfomer? and if so, which transformer?
Thanks in advance!
Blake
Thunderbayforrent.com
  1. DanH | Feb 26, 2012 09:30am | #1
    Is this even worth the effort?  A thermostat battery should last several years.
  2. PeteBradley | Mar 07, 2012 10:47pm | #2
    Thermostats draw very little.  I get an easy couple of years out of my batteries.  You'd need some code-approved installation of a transformer that output the correct DC voltage for your stat.  It's just not worth it.
    I don't know if you're looking for an "off the grid" approach but shelf life of a set of batteriestoday  is such that you might as well just keep spares in cold storage.
  3. rich1 | Mar 09, 2012 12:13am | #3
    I'm guessing that it's a boiler, not a furnace.  And that the zone valves are in the apartment.  If that is the case, there is a common wire at the zone valve.
