I need to move a thermostat. Can I splice the wires and only run new from the current location or must I run new wires from the furnace? It would not be any more work to do an entirely new run (walls and ceilings are open).
Making your own heated floor assembly may save money, but it can also cause problems.
You can splice the wires. But if it's really no more work, I'd run a new intact one. Most electrical wiring failures occur at splices and terminations.
Ed
I'd suggest that you solder those little wires if you're going to splice them. No way would I trust anything else I've seen, not to fail at some point.
If it's just as easy to get a small spool of the stuff and run it fresh, that's what I'd do too.
What edlee said.
Qualifier - if the splice location can be moved to a location that will remain exposed once the building is finished - I would not hesitate to splice.
Small wire nuts or twist, solder and heat shrink. Leave some slack or a small loop at the splice just in case of a future problem.
If a dampish location like a dirt floor crawl space - I like to use the closed end crimp connectors (look similar to a wire nut, but crimp on). Twist wires together, crimp on the connector then fill the connector cavity / opening with GE Silicone II - corrosion ceases to be an issue even in a boat bilge. USCG approved for Inspected Small Passenger Vessels.
Jim
Never bury a splice. Run new - as you said, its open and no big deal...
