THICKENING PAINT TO FILL NAILHOLES
loud | Posted in General Discussion on August 5, 2002 05:48am
does anyone know a way to thicken latex paint so that it will fill countersunk nailholes when applied with a brush?  I’ve build a coffered ceiling and have a number of nailholes to fill.  I was going to try adding Savogran’s level best to the paint.  It is a wood filler when mixed with water.   Also, does anyone know a recipe for Swedish Putty?  Thanks to anyone that responds.
  1. Mooney | Aug 05, 2002 06:06am | #1
    mmmmmmm, Paint mixed with joint compound will fill nails and other things. I use it for a texture and to hyde sand paper marks. Depends on how bad these nails are you are talking about . It wont fill a raw drywall nail, but it will fill finish nails used to hang pictures. Ive used calking to repair a few nails on a ceiling , then paint over later on .
    Tim Mooney
  2. Piffin | Aug 05, 2002 06:07am | #2
    It took me a few minutes to figure out whether this was a joke or not.
    Deal with the nail holes by using non-shrinking spackling, spread with a flexible putty knife. It dries in twenty minutes to an hour. A light sanding will make it disappear, texture wise. Then do your painting.
  3. luvmuskoka | Aug 05, 2002 12:33pm | #3
    O.K. this is kinda weird. I have been working on my library all winter. Just finished the painting stage of the casework and had left a small container of paint and an artists brush sitting next to the computer.. After about a day I mixed the semi/hard paint with the brush and started to touch up the finish nails. The toothpaste consistancy of the paint worked great!
    Ditch
    1. MisterT | Aug 05, 2002 01:25pm | #4
      What is this ???
      Fine Shortcuts???
      Yeesh!!Do not try this at home!
      I am a trained professional!
      1. luvmuskoka | Aug 05, 2002 01:47pm | #5
        The nails were already filled and sanded before painting, but because I used a high gloss paint you could still see some of  them. I stumbled on this because I was posting instead of painting.
        Ditch
        1. Mooney | Aug 05, 2002 02:17pm | #6
          we are going to get through this
            Flathead | Aug 05, 2002 04:04pm | #7
            Does this mean I don't have to sand anymore?
          2. Mooney | Aug 05, 2002 04:18pm | #8
            You have to answer your own boss , I have to try to answer mine . But she sure is getting harder to please !!!!!!
            Tim Mooney
Choosing a Paintbrush
  • The New Old Colonial
