thin concrete or mortar floor?
Hangnails | Posted in General Discussion on September 12, 2005 07:53am
Hi all,
I have a front room with 2×6 t&g subfloor.  The subfloor elevation is approximately 1/2″ lower than the finished floor in the adjacent room.  Is it possible to pour a mortar or thin set floor that is only 1/2″ thick and end up with a solid and stable floor?  Has anyone done this and used acid stain?  If this would work, what would you suggest as preparation?  I was thinking tar paper, mesh, mortar.
Thanks,
Rob
    BillHartmann | Sep 12, 2005 04:40pm | #1
    With in the last 1-2 years JLC ran an article on doing just that.
    The guy does a thin "slab" over wood and concrete floors just for doing paterned, stamped, and stain concrete finishes.
    Go to JLCONLINE.com then Research and you can find the article. There is a nominal cost.
    1. Hangnails | Sep 13, 2005 07:20am | #2
      Thanks, I'll check it out.
Fast, Accurate Wall Framing
