Thin wall conduit okay next to ACQ wood
housenut1 | Posted in Construction Techniques on September 6, 2011 11:12am
I plan to hide thin wall conduit behind some 1x cedar on a outdoor porch.  It will sit in a routed groove in ACQ treated. Will it corrode earlier because of being in contact with the treated?  The other option is liquid tight.  Any thoughts?
Wayne
  1. DaveRicheson | Sep 07, 2011 06:09am | #1
    Not sure if the galv. on thinwall is up to ACQ. Maybe if both stay dry, but all bets are off ifthey get wet.
    Why not pvc?
    1. housenut1 | Sep 08, 2011 10:21am | #3
      Thanks Dave it makes sense and is probably cheaper than liquid tight.
      Wayne
  2. DanH | Sep 07, 2011 07:46am | #2
    Wrap the conduit with, eg, rubber peel&stick flashing -- something that is both an insulator and reasonably waterproof.  (Plain electrical tape would work fine for short slots, but would be tedious for any substantial length of conduit.)
    (PS:  You may want to think about placing a nail plate (or several) over the conduit along the line of your siding nail pattern.  It's easy to forget where the conduit is while hanging siding, and a nail CAN penetrate thinwall.  Do this in spades if you use plastic instead.)
    1. housenut1 | Sep 08, 2011 10:22am | #4
      Thanks Dan I probably would of forgot to do that and I'll probably use PVC too.
      Wayne
Fast, Accurate Wall Framing
