thinset over drywall
cutawooda | Posted in Construction Techniques on March 17, 2009 06:57am
taking my tile from the wet area of the bathtub and forming a tile wainscotting behind the toilet and sink. wet area will be durock but i want to transition to green sheetrock at the waiscotting location. Can I continue to use the thinset over the sheetrock or do I need to also transition to mastic when i hit the sheetrock.  I guess my question is can you use thinset over drywall or does the moisture from it harm the drywalll.
  1. YesMaam27577 | Mar 17, 2009 02:13pm | #1
    >>"...can you use thinset over drywall ...."
    Yes.
    Politics is the antithesis of problem solving.
  2. DonCanDo | Mar 17, 2009 02:28pm | #2
    I'm not sure, but I would think that you would want to prime the drywall first so that the moisture doesn't get sucked out of the thinset too quickly.
  3. Piffin | Mar 17, 2009 02:32pm | #3
    no problemo
Installing Prefinished Cabinet Molding
Use these assembly techniques when installing crown risers and molding to minimize visible gaps and nail holes.
