Thought I might post some pictures of my first floors in six years. These are going in my girls bedrooms.
Seems as though my pics are all larger than 4.0mb in Picasa. Can I reduce the mb?
IrfanView is one (shareware) tool that folks here use. If you hold your mouth right it will even do "bulk" transformations of all the files in a directory, etc.
You can also link directly to Picasa rather than uploading.
here we go
This is a log cabin corners floor going down.
ditch
Good to see you back. What's been going on?
Spent the last 6 years getting better since my accident with a drunk driver in '05. My tools were in a trailer for 5 of them.
Thanks for asking.
Glad to hear you're back!
Your name pops in my head everytime I use the multimaster.
Thanks!
You going to fill in with some more pictures? You can embed them in the message now if you want to add some narrative.
Everytime I use my Multi-Master I think of all the people I turned on to this life changing little saw.
Fein asked for my feedback on the tool in 2002 or so. I spoke with the president at the time, his name was Major, and I told him my two major concerns were blade cost and the fact that we (floor guys) needed something that could withstand hitting a nail or staple and not blow 25 bucks out of my wallet. Make a better blade cheaper.
Dissapointingly they did neither. Now Harbor Freight sells a decent set of blades, some bi-metal, and the cost is down to about 5 dollars.
Moral; ALWAYS listen to the people in the field, your engineers aren't buying your tool.
Lucky for us........
blade cost has come down. That indeed was the only killer. Hard to pass on the cost to the customer............"are you kidding me-who'd you get it from............a swiss watch maker?"
And now with what started with infomercials and then proceeded to hands on displays in home improvement stores, fein reinvented their marketing strategy. Now every (sort of) Tom Dick and Harry has one. With the cheaper knock offs, even those guys and their brother in laws have them.
The day of the magician is fading.
Good to know you are still verticle Ditch
Still verticle man, takes me awhile to get warmed up though.
One day at a time
More patterned floor pictures.
Finished sanding and water popped the floors in preparation for staining tomorrow.
Ditch
Explain this "water popped" please.
"Water Popping" is just an
"Water Popping" is just an age old way to raise the grain. It allows stain to penetrate deeper and more evenly. These are Ash floors and I'm staining them white with an exterior deck stain thinned 2:1 wiped quickly to effect a "milk paint" look.
I've wet the wood and then (when dry) sanded, prior to using a water-based stain, so that the stain wouldn't raise the grain. Do you sand after, or just stain over the "water-popped" surface?
Stain over the raised grain. It will be like sandpaper but the finish will smooth the floor out and abrading between coats will knock off any grain reaching through the stain and 1st coat of finish. When you sand over raised grain you are essentially going back to pre-water-popping mode.
So the finish and screening will bring it back to smooth, eh?
Thanks.
With certain species of wood, when you sand it, the stray hairs of grain are foirced down into the surface.
when you add wtater or a wtater based sealer, those grain hairs stand up straight, like porcupince quills at alert.
That lets stains penetrate better.
Or if you used a sealer, and sand off those veticle haitrs while they are stiff, you get a smootyher finish in unstained work
yessir
I understand the raised grain with water idea. Just never knew it added to applying stain.
I'm gonna have to try this sometime.
