Three-Season Room
user-162289 | Posted in Energy, Heating & Insulation on September 19, 2007 09:18am
94723.1
I have a raised ranch.  At the back of the house, you can walk out of the lower level onto a patio.  Above the patio there is a three-season room.  It sits on 2×12 joists that are attached to a ledger board at one end and sit on a beam near the other end.  There are several electrical, telephone and cable/internet wires run along the joists and through holes in them.  I would like to insullate, in order to keep the three-season room warmer, and cover the joists to create a ceiling over the patio.
Also, a small area on the underside of the three-season room’s plywood floor has sometimes gotten damp near one of the room’s corners.  I think I have fixed the problem, but it is an intermittant problem so only time will tell.
1.  What are the best options for insulating the three-season room floor, considering the wires and the, hopefully corrected, intermittent water problem?
2. What are the best options for closing in the joists to create a ceiling over the patio?  I like the traditional look of narrow boards, but it would also be nice to be able to remove section of the “ceiling” to update wiring or to check on the intermittent water problem.
I would appreciate any suggestions as to materials or methods to use.
  1. rez | Sep 24, 2007 09:05pm | #1
    Greetings Chuck,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    sobriety is the root cause of dementia.
  2. DanH | Sep 24, 2007 09:25pm | #2
    Not quite the same scenario, but to slightly extend the season for our 3-season porch I made "screens" to fit under the deck and covered them with hardware cloth and then landscape cloth (hardware cloth on the bottom). Then stuffed FG insulation into the joist cavities and closed the screens, securing them with turnbuttons. (Had run pieces of wood across the joists like strapping to provide "frames" for the "screens" to fit into.)
    This scheme provided the ability to access the area to retrieve stuff that fell through the deck floor from above, and also assured that the area would be able to dry reasonably well, in the event that some rain blew in.
    You could do the same, only used spaced boards in place of the hardware cloth and something more attractive than the turnbuttons to secure them.
Fast, Accurate Wall Framing
