Tile adhesive dry time on cold floor
Ted W. | Posted in General Discussion on March 27, 2008 05:44am
I finished puting down about 450 sq. ft. of tile on a cold basement floor. The tiles are porcelain, 12″ x 24″ and the floor is concrete slab with cut-back from the old asbestos tiles, which were removed. The floor is kind of cold, maybe 50 deg F. The mortar I used is latex modified, mixed with water. I used a 1/2″ notched trowel because of the size of the tile and uneven floor surface.
One thing I noticed is the mortar does not set, but is dependant on drying. How long should I give it before grouting?
Cheap Tools at MyToolbox.net
See some of my work at AWorkOfWood.com
  1. rez | Mar 28, 2008 08:53pm | #1
    Greetings Ted,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    Get a Peach full,
    easy feelin'.
      Ted W. | Mar 29, 2008 09:20am | #2
      Thanks Rez, but it's getting grouted Monday. I think 4 days is more than enough dry time. =)--------------------------------------------------------
      Cheap Tools at MyToolbox.netSee some of my work at AWorkOfWood.com
Outdoor Lighting
