i had a close call with a 12×12 marble tile falling about 10 minutes after installation. i completed the job 3 tiles at a time using “deadmen” of 2×4
to hold overnight.i was using thinset and additive over cement backerboard.
any tips? trowel sizes ? buttered or trowelled?
Listeners write in about ambitious projects and sinking patios before asking questions about old house specialists, attic headroom, and home shops.
Assuming your backerboard is secured firmly in place, I'd say you probably had used too much thinset and/or the thinset was too "loose". For marble tile, movement of even 1/16" out of plane is too much, so put away the trowel and backbutter the tiles with a stiffer mix.
Backbuttering is actually a two stage process. One, skim coat the tile to "ground" the thinset to the tile; two, build up the thinset so it will a)be enough to allow exact placement of the tile, b)be adequate for 100% coverage (for marble).
Just be glad it was you who had the close call and not your customer.
*Like Rich said I'd backbutter those large tiles. The only thing I do in addition to backbuttering when setting a ceiling with larger size tile is to put a very thin coat of thinset on the backerboard with the flat side of the trowel first. Really push it hard into the surface. I think this helps the tile "grab on". Good Luck.Dave
i had a close call with a 12x12 marble tile falling about 10 minutes after installation. i completed the job 3 tiles at a time using "deadmen" of 2x4
