Tile backer-board tip
McDesign | Posted in Construction Techniques on November 8, 2006 03:33am
Always scraped off the little mushrooms off that the rock-board screws leave, with my thumb.
This time I hit ’em all at the end with 60-git in the palm sander – knocked them all down quick as a wink, and no blood.
Yeah, I know I should be using Shooter-Turdy high-monkey-monk stuff, but darnit, I’m just scared.
Forrest – deck mud tomorrow
  1. davidmeiland | Nov 08, 2006 04:51am | #1
    What type of board you use?
    I generally use Durock and with an impact driver I can get the screws flush with nothing sticking up. If there are tiny blips the thinset goes right over them. With Hardi it's a lot more trouble to get everything flush.
    1. build_one | Nov 08, 2006 05:51am | #2
      We used to use durock, but now we use hardi.  No real problem with the durock, maybe it was a local industry shift.  Only advantage I'm aware of is we used to score durock and break it, whereas with hardi we can cut it with a saw.  Also durock has countersunk holes for screws and has one inch grids all over it.
      1. BillBrennen | Nov 08, 2006 06:07am | #3
        Countersunk holes???? How long has this been so? I've never seen it, and did a Hardi job just recently (under the Kerdi - belt and suspenders, doncha know.)
        Dinosaur | Nov 08, 2006 06:44am | #4
        Yeah, me neither. I mean, me, too, I've never seen neither the holes or the grid. The only thing my Durock board has printed on it is DUROCK.
        Impact driver does work, tho. No 'shrooms.
        But I cut it with a 4" diamond blade in an angle grinder. Score-n-snap makes me too hinky on $80-a-pop sheet goods....Dinosaur
        1. alwaysoverbudget | Nov 08, 2006 04:47pm | #7
          80.00 a sheet,what kinda hardi are you using? anyway all of the 1/4 hardi i buy has the 1" grid and indentions every 8" for the screws.makes for easy layout.i buy it at a big box 9.95 a sheet.larryhand me the chainsaw, i need to trim the casing just a hair.
            Dinosaur | Nov 08, 2006 08:46pm | #8
            It's not Hardibacker; I'm using ½" thick Durock. I gave up using the ¼" stuff years ago after seeing the screws pull through from the weight of the slate I'd hung on it. That would have been a very expensive call-back if it hadn't been in my own house.
            Anyway, that $80/sheet price was an OOPS. I just checked my invoicing database (instead of my CRAFT-ridden memory) and we were billing it at $47.19 a sheet last April.
            I've been told you can score and snap the ½" stuff, but even at a 'measly' 50 smackers each, I don't wanna take a chance of screwing up. Just call me chicken, LOL.
            The 4" diamond blade in a grinder cuts with a lot less dust than a full-sized carborundum disc in the circ. When I have lots of small strips to rip precisely (say, for a curb on a walk-in shower) I'll use the TS and wear a mask....Dinosaur
          2. jet | Nov 08, 2006 09:01pm | #9
            That's what I thought, $47 per.
            I know yer way up north but not that far!!!!!!
            Delivery is expensive to you huh???
            What's gas at ?? $10 a liter???Poor Owl will just have to pull that sled all by himself. Can't afford to truck up any more sled dogs HUH?"No doubt exists that all women are crazy; it's only a question of degree." - W.C. Fields
            Dinosaur | Nov 08, 2006 09:26pm | #10
            Why do you think I bought a full-sized truck? Lovely thing to be able to slide in 4x8 sheet goods and close the tailgate....
             Dinosaur
          4. jet | Nov 08, 2006 09:32pm | #11
            Yeah there are times that I envy your big one!!!!! Hehe!"No doubt exists that all women are crazy; it's only a question of degree." - W.C. Fields
            Dinosaur | Nov 08, 2006 10:29pm | #12
            I wouldn't touch that line with a 10-foot story pole....Dinosaur
      McDesign | Nov 08, 2006 06:59am | #5
      1/2" Hardi; 16" OC studs.
  2. DanH | Nov 08, 2006 07:00am | #6
    Yeah, you've been screwing that up big time. You're supposed to snort the mushrooms.
    People never lie so much as before an election, during a war, or after a hunt. --Otto von Bismarck
Mortar for Old Masonry
