Tile corner shelves
bigbossman | Posted in General Discussion on June 22, 2007 05:13am
Is there any special glue or adhesive that is used to put the corner shelves in on a tile surround for a tub or is it just mortar that holds it in?
    Mongo | Jun 22, 2007 05:54am | #1
    I use plaster of paris.
    MikeMicalizzi | Jun 22, 2007 08:32am | #2
    I use Liquid Nails then duct tape it for added insurance just in case it gets bumped.
    1. bigbossman | Jun 23, 2007 04:31am | #3
      I shouldn't use mortar then when setting the tiles and corners for the corners I should use Liquid Nails. Right?
        MikeMicalizzi | Jun 23, 2007 06:06pm | #4
        I prefer the Liquid Nails because it dries faster than the mortar, but that's just my own preference. Warning - the Liquid Nails can be a little messy and doesn't like to clean up like caulk, a good tip is to put tape over the tiles as close as you can where you'll be glueing, as to protect them from getting gooped up.
          BillHartmann | Jun 23, 2007 09:48pm | #5
          I don't know how a caulk remover is going to hold up a shelf!!!http://www.liquidnails.com/ViewProductDetails.do?productId=49.
    EricPaulson | Jun 24, 2007 12:59am | #6
    Done correctly, the shelf is held in place by the tile.
    Just grout it in place.
    [email protected]
    Edited 6/23/2007 6:02 pm ET by EricPaulson
      EricPaulson | Jun 24, 2007 01:04am | #7
      Corner shelf
      [email protected]
      Edited 6/23/2007 6:04 pm ET by EricPaulson
      Edited 6/23/2007 6:05 pm ET by EricPaulson
    DDay | Jun 24, 2007 06:28am | #8
    Never seen it done differently than Eric's post. It's a corner shelf so it supported on about 2/3's its sides. It will hold very well when installed correctly.
  • A Postwar Comeback
