Working on my kitchen. The first thing I ran into, of course I knew about but didn’t think until I started.
Here is the problem. I have a tile floor, with 2″ of concrete underneath.
What would you do to remove the concrete?
sledge, pinch bar, hilti hammer drill.
...pray theres no metal lathe
.sledge, pinch bar, hilti hammer drill.
I was afraid of that. I was hoping someone knew of a shortcut.
Metal also:(
That is the shortcut.....
Really , with a hammer drill and a wide bit an average bath will only take a couple hours from start to clean up.
dug
Sometimes the quickest and easiest way to get it done is to stop looking for the quicker and easier way, and just get it done. =)
See my work at TedsCarpentry.comBuy Cheap Tools! BuildersTools.net
If you haven't already done so, please update your profile. Since many issues are dependant on the region in which you work, we often look at your profile to see where you are writing from.
Edited 12/5/2008 7:25 pm by Ted W.
I know, I am procastinating>G<
Jackhammer.
Go easy. Short bursts and don't lean on it.
G'wan, admit it. You've always secretly wanted to run one o' those things....
Dinosaur
foolish men call Justice....
or a tile removal machine. ask for a vct stripper, depot & Lowes rent them. they work."this dog may be old but he ain't cold. And he still knows how to bury a bone."
Lattimore
http://www.rehmodeling.com
That wet bed is probale there for a reson .
what's under the 2" of concrete?
felt on ply? slab?
I might try cutting the mortar bed into 2' x 2' sections and popping them up with a pinch bay if I thought they would be free from the substrate. if its mud on slab, I'd use the rotohammer.
k
Wood flooring.
in that case I probably would try to pry/crack it into sections. i guess if there's chicken wire or lath, that may be nailed down, but even so...
If you can lift an edge a smidge, or maybe cut a trough through the middle, then get a bar under it, set a wedge or block, you should be able to score it and crack it. it's easier to break if it's got room underneath for bending, and i'd also rather take out bigger chunks than rubble and dust. goes for walkways and slabs, too.
the hardest part is usually getting that first chunk out.
k
Are you trying to remove the tile or the concrete or both? If it's just the tile, I've seen it done with a square-tipped garden spade.
Scott.
Always remember those first immortal words that Adam said to Eve, “You’d better stand back, I don’t know how big this thing’s going to get.”
Both
