I would like to inset some tile mosaic strips into a concrete patio pour. The tiles are 3/8″ thick with an overall width of just 2″. I would like to do several long strips that would be 10′ to 15′ long. Any ideas on how to make a slot for them during the pour of the patio? I would set the tile with thinset and grout into these slots after the concrete has set.
Wood strip - remove after initial set? Sort of like the key in the top of a footing.
Just a thought, not a concrete expert.
Jim
Strips of rigid foam 1/2" thk x 2-1/4" wide, mash them down into the wet concrete and melt them out a couple of days later. propane torch, kerosene, whatever.
Cut a board the thinkness of your inset, then wrap it in wax paper and staple it to the board. You might want to use plywood to keep it straight.
Also a CRX fanatic!
If your hair looks funny, it's because God likes to scratch his nuts. You nut, you.
FastEddie says "use foam". I agree. Cut it thick enough to allow room for the thinset, and wide enough to allow for grout around the tile edges.
I just used some foam to create a "cutout" in a concrete pad. Worked like a charm, and was easily removed after the crete cured -- an attribute wood does NOT have -- and it did a good job of leaving a nice, square recess. No need to melt, etc., since it was so easy to just pull out.
Mike Hennessy
Pittsburgh, PA
I was remembering when I was on a power plant foundation project in the late 70's and we used styrofoam to create keyways between pours. It came out real easy when it was sprayed with gasoline. Or maybe it was acetone."Put your creed in your deed." Emerson
This sounds interesting. Is there a problem keeping the foam down and also finishing the concrete around the foam? Thanks for your input.
There should be enough friction to keep the foam in place. It's only 1/2" thick. Be sure to make the foam a tad bit thicker and wider than the tile insert. Lay a scrap 2x4 on top if it starts to rise. Even better, use 3/4" thick foam to leave some tolerance in case it does rise a little. Better to have the groove 1/8" too deep than 1/8" too shallow.
I think we tied the foam to the rebar with tie wires. Remember, this was for a foundation for a power plant. The keyways were at least 2x4 and the pours were in the range of 100+ yards ... lots of room for rough measuremsnts. "Put your creed in your deed." Emerson
Mike, Thanks for your input. What keeps the foam from rising up in the concrete?
Same thing that keeps a wood form from floating. ;-)
The mix I used was not soupy enough to cause the foam to float. I placed the foam on the crete when the bottom was at the correct height, and placed the final layer of concrete around it. If you're worried about it floating, weight it down with some bricks or similar. I didn't need to.
BTW, the gasoline or acetone sounds like a lot of fun <G>, but it's really no big deal to just pull the foam out. It deforms enough that it comes out quite easily.
Mike HennessyPittsburgh, PA
