Tile on exterior deck
immrfxit | Posted in Construction Techniques on July 25, 2005 02:18am
I am getting ready to build a raised deck on the back of my house, and would like to use a frost proof ceramic or porcelain tile or 1/2″ paver for the deck floor.  Does anyone have any advice or ideas for me?  I thought about spacing the joists 12″ O.C., using 2 layers of 3/4″ exterior toung & grooved plywood, even trying the the uncoupling membrane featured in the latest issue of Fine Homebuilding.
I live in Illinois by the way.  Thanks in advance…
  1. FastEddie1 | Jul 25, 2005 04:26pm | #1
    You don't necessarily need to space the joists closer.  A deck structure of 2x12 @ 16" is no different than an interior house floor of the same construction.  Justr be sure the joist span is short enough ... 10-12 feet would be a max, and that should be easy to accomplish in a deck.
    Your problem is going to be keeping water off the plywood.  Here's a product I have a sample of, but I have no idea if it would work.  Quoting from the brochure: it's DalTile Dal-cim 500 crack isolation membrane and sound control underlayment.  40 mil peel & stick.  Can be used for inbside or outside application.  Service temp range -20 to 189 F.
    Maybe if you covered the top of the ply and wrapped that over the edges it would keep the ply dry.
  2. davidmeiland | Jul 28, 2005 04:26am | #2
    Waterproofing exterior wood decks like this is a trade all it's own. If you want to tile directly over it, I would look at waterproofing membranes from Laticrete. With a little work you can probably find a number for tech support and talk to one of their applications people.
    Ed is correct about the joists. I think you might want to use 1-1/8" plywood.
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
