tile question
wannaknow | Posted in Construction Techniques on July 4, 2011 08:11am
At work we put ceramic tile over linoleum which sits on concrete. When I was done I tapped on the ceramic tile with the back of my scrapper handle and all the tiles sounded hollow. The other bathroom, done by another guy, had the same sound–like trapped air or somehow hollow. The old tile seemed sound except for a few tiles. We also used some acrylic (I think) compound that took forever to dry. Was there a better way to do this and also if there was asbestos in the linoleum how do you take that out safely? The book says contact EPA, but they only say not to saw or shatter. Is lifting it out with a floor scrapper safe even though some pieces will crack and break into pieces? What’s right? What’s safe? And why did all the tiles test hollow?
  1. calvin | Jul 04, 2011 08:36pm | #1
    jd
    How big were the tiles and what groove trowel did you use.
  2. DanH | Jul 04, 2011 09:32pm | #2
    Uh, what did you use to set the tile?  You said "some acrylic compound".  Do you mean mastic (vs thinset mortar)?
  3. leandsons | Jul 05, 2011 09:29am | #3
    sounds like you have problems to come...
    I have been remodeling for the last 15 years and usually do everything  by the book unless I find a better alternative based on experience.  First, I would not tile over linoleum because it is not the right substrate for tiling.  Second, it sounds like you use an organic product like mastic or premixed "thinset".  Neither of these can cure properly when sandwiched between linoleum and ceramic tile because neither is pourous that would allow these setting material to dry.  It is just like the environment when mastic is placed in a container with a closed lid; it will not dry or set.  on the other hand, regular thinset or unmodified thinset would set and does not need to "breath".  I would have taken good care and remove the linoleum.  just look into safe ways to contain the dust and air when you do so if you're concerned with asbestos.
    I think the hollow sound might be a result of the adhesive that you use remained wet.  It is also possible that you did not use the right notched trowel and use too little setting material so it is really hollow underneath.  in either case  you can probably removed all those tiles easily once you remove the first 1-2 tiles.  i say you redo it now or redo it down the road; your choice :)
