Tile Question (sort of)
JohnD1 | Posted in General Discussion on May 26, 2009 01:59am
I was given some 1/4″ thick granite tiles, and I have a ledge that is begging to have them applied. It is 3 1/2 inches wide (Left-over from an unusual construction need). I have the diamond saw; used it to cut every tile that I placed around the fireplace)
What I want is some ideas to support the tile so I can have the shelf that is a little wider than the existing ledge. I have mocked up some floor trim upside down; I don’t like it but maybe another shape? Any other ideas?
    Dinosaur | May 26, 2009 02:31am | #1
    ¨ú" ply topped with ¨ý" ply, screwed and glued together. Make sure the substrate can't move once you mount it to the actual ledge.
    Dinosaur
    foolish men call Justice....
    1. jet | May 26, 2009 02:46am | #2
      What planet are you from??????????Piglatin ain't spellt that way dude
        Dinosaur | May 26, 2009 03:26am | #3
        Atwhay igpay atinlay?
        Dinosaur
      2. KFC | May 26, 2009 04:13am | #4
        You ply.  Why ply?
        k
    2. FastEddie | May 26, 2009 05:52am | #5
      Wow, somethng didn't translate properly.  You probably can't see it on your pc. "Put your creed in your deed."   Emerson
        Dinosaur | May 26, 2009 06:53pm | #7
        Damn and tarnation. Youse guys gotta set yer 'VIEW'/'Encoding' sub-menu to read the split fractions my keyboard produces using the multi-lingual character-set. I'm set for 'Western Eurpoean (Windows)' encoding 99% of the time....
        That was supposed to read 'three-quarter ply' and 'five-eighths ply'.
        Dinosaur
        1. FastEddie | May 26, 2009 09:19pm | #11
          Well, down here in the Lower 48 we are set for 'mericun.  We broke from the western european methods back in 1776.  Too bad your reps in Quebec are still tied to the Frogs."Put your creed in your deed."   Emerson
            Dinosaur | May 27, 2009 08:53am | #12
            Too bad your world view is so tiny.
            Dinosaur
          2. FastEddie | May 28, 2009 04:40am | #13
            Reminds me of a movie from ... I think ... the 60's.  The Ugly American."Put your creed in your deed."   Emerson
            Dinosaur | May 29, 2009 02:25am | #14
            Yeah, well, I've been working hard at not being one for well over 30 years. Figger it's the least I can do for the rest of youse guys.
            Dinosaur
    3. JohnD1 | May 26, 2009 04:53pm | #6
      "¨ú" ply topped with ¨ý" ply, screwed and glued together"
      Thought of that; I was only thinking about an inch of overhang, which would be enough for the junk that we lay on that ledge.  And, with the plywood, there is the problem of making the edge look good.  (Laziness is my name whenever possible)
      I think something like a mini crown molding would look OK; maybe even a triangular piece of wood painted to match the walls.  The ledge is about 18 inches from the floor, and the support would not be really visible.
        Dinosaur | May 26, 2009 06:56pm | #8
        An inch of overhang? Use 5/4 pine or maple, stain and varnish the edge to match the tile colour, and set a metal or plastic tile-mould under the tile to cover the vertical edge of the tile.
        Dinosaur
        1. JohnD1 | May 26, 2009 08:12pm | #9
          Now that was just too d*** simple!
          I'm glad I thought of it! [grin]
    aimless | May 26, 2009 08:23pm | #10
    How about edging the front with the same tile?
Rescuing Old Hardware
Whether it’s already in your house or picked up at a flea market, vintage hardware almost always needs help.
  • Ramon Martinez, Site Supervisor
  • What Size Nails?
  • Stop Ice Dams When Reroofing
  • Outdoor Lighting
