OK so my bathroom shower walls are just about tiled completely.
The paper it came with said to be sure to seal the tiles. Its a crackled glazed tile. HAs that old feel to it.
I have tons of a good “marble” sealer left and wondered if I could use that or should I buy a different sealer. Seems to me sealers have a lot of the same ingrediants. I’d probably give it a good half dozen coats so……
Be sealed
Namaste
andy
“As long as you have certain desires about how it ought to be you can’t see how it is.”
Got any leftover tiles? Try to apply some on a sample tileand see if it affects the look of the tile. Also see if it seals it the way you want it to.
If at first you don't succeed...try again! After that quit! No sense being a dam fool about it! W.C.Fields
jet
yeh, I did that just wondering long term. Spose I have plenty of sealer and can do it easy enough a few times a year,
Thanks"As long as you have certain desires about how it ought to be you can't see how it is." http://CLIFFORDRENOVATIONS.COM
If there is no change in the tile then I see no problem. See if pouring water on the tile sokes into the tile.If at first you don't succeed...try again! After that quit! No sense being a dam fool about it! W.C.Fields
