I have electric cable heat specified for my bathroom tile floors. We will use Easy Heat, a product that goes down as a continuously looped cable, held to the subfloor using the loop-end strips that staple down first. We won’t be putting the cabling under the vanities. When you do this, do you tile under the vanities? I am inclined to not do it, instead, placing a temporary cleat board along the inside line of the toeboards, and tiling to the cleat.
Dangerous electrical work and widespread misconceptions cause fires, deaths, and $1.5 billion in property damage annually.
either or.
Last one I did I tiled where the vanity was going to be set ....
just fattened up the thinset so the tile would lay flat ..as the heat mesh holds it up about an 8th.
Job right before that I was limited on space and wanted to get the vanities out of the BR ..so I installed them first .... on scrap 1x.
after runing the heat mesh ...that still gave enough room to slip the last coupla tiles under the boxes ..... then base as per the norm.
So ...either way'll get ya there.
I didn't run tubes under the vanity and usually never tile first anyway. I stopped the heat at the kick. I wouldn't run the heat under there or your wifes makeup will melt.
Do remember to run heat under the tiled deck of the drop in tub. Your wife will love you.
Quittin' Time
When tile is cheap I tile under vanities. When it's expensive, no, or I buy cheap tile for underneath. It also depends on box quantities. If I have enough I do it, but I sometimes won't purchase an extra box to do so.
If you want to do a premium job then do it. The one disadvantage of not doing it is that if you flood the floor, it kind of creates a pool.
I wouldn't bother with the cleats. Just mark a line on the floor where the vanity goes, and run full tiles beyond it, without taking the time to cut them.
An emphatic YES. While there is no reason to run the heating system beneath the vanity, I think it`s imperative that the tile cover the entire floor. If the tile is installed properly, it will last indefinetly. Five, ten or maybe fifteen years from now the vanity may not be desireable. You won`t be able to find the tile to patch the floor and you will be locked in to the size and design of the vanity you install today.
I`m just going to pick some random numbers to throw out...even if the vanity measure five feet in length, you`re only talking about ten square feet of material. If you`re choosing a $10 per sq./ft. tile, you`re talking about saving $100. Unless that cost is going to break the bank on this project, I don`t see it as a reason not to tile beneath the vanity. You certainly won`t be saving much if anything on labor.....the area will still need attentioning in order to install the vanity.
J. D. Reynolds
Home Improvements
"DO IT RIGHT, DO IT ONCE"
