tiled backsplash – window trim
lockmiter | Posted in Construction Techniques on May 10, 2007 02:53am
i am tiling a kitchen backsplash and there is a window behind the kitchen sink. i am conflicted with the best relationship of the window trim and the tile. does the window have an apron, does the window sill (stool cap) get notched to fit over the tile, does the tile get notched around the sill. what is the bast way for the two finishes to relate.
  1. FastEddie | May 10, 2007 03:24pm | #1
    The best way to do this is to ask the wife how she wants it.  You can do a no-sill/no-apron trim, tile sill, wood sill, whatever she wants.
    JDRHI | May 10, 2007 04:23pm | #2
    Often depends on the trim style. If the trim is condusive to picture framing, you might try that and cut tile to it.
    When not, I typically go without an apron. I extend jambs to accomodate tile thickness. Install backsplash first, and trim atop tile, notching the stool as necessary.
    If backsplash does not continue up entire height of window, I fill gap between trim and wall with solid wood.
    J. D. Reynolds
    Home Improvements
