Tiles on Concrete Floor
Elbert411 | Posted in General Discussion on April 14, 2008 03:11am
 Question? Can I lay tiles on a concrete floor? Or must I place 1/2 cement board on concrete first.
 Help?
Elbert
  1. gofigure57 | Apr 14, 2008 03:16pm | #1
    yes
    IMERC | Apr 14, 2008 03:29pm | #2
    go for it....
    use thin set and not mastic....
    WOW!!! What a Ride!
  3. cliffy | Apr 14, 2008 05:03pm | #3
    Concrete is a fantastic base for tile.  Make sure any dirt, paint or flakes are cleaned up.
    Have a good day
    CLiffy
  4. billzbz | Apr 14, 2008 06:52pm | #4
    I just did one.  Read the thinset label - it says it is ok.  I got a wire brush with a handle for leverage and roughed up the surface a bit, shop vaced the debris and laid the tile.  One word of caution:  If the concrete is cold and the ambient air warms up while you are laying tile the concrete will sweat and may hurt the thinset, so warm up the concrete or avoid situations where the concrete may sweat (water condenses on the warm side of a cold surface, like a bottle of beer).
    good luck,  Bill
    1. Elbert411 | Apr 16, 2008 07:28pm | #5
      Thanks,
       I have this notion that I should first lay backerboard. However, I'm going to place them on the crete.
       Thanks to all for the info.
      1. atrident | Apr 16, 2008 11:35pm | #6
         Is the slab cracked? If so you might  need a membrane between the surfaces to decouple them. Check out Schluter  ,they make some of the best,but the cost goes up. Just make sure you have extra tiles so if any break you can replace.
        Edited 4/16/2008 4:36 pm ET by atrident
    2. fingers | Apr 17, 2008 03:55am | #8
      Why would anyone want to tile a bottle of beer?
    Dinosaur | Apr 17, 2008 12:57am | #7
    The real answer depends on the condition of the slab. If its poorly finished, humpy/hollowed, or cracked, you will have to address those issues first, possibly by using some SLC to obtain a uniform, flat surface.
    It also depends to some extent on the size of tiles you plan to lay. Smaller stuff--1x1 or 2x2 or 1" hex mosaïcs--won't crack as easily as the big 12x12 and 18x18 muthas.
    Other than those issues, concrete makes a very good base for tile. Remember that CBU is merely a convenient way we use to install a 'modular concrete' floor in places where we wish one existed but it doesn't. Thinset is the way to go, as others have mentioned.
    Dinosaur
    foolish men call Justice....
