Tiling a countertop
| Posted in Construction Techniques on June 16, 2005 02:51am
Looking at doing a small island in tile.  It’s only 32 x 48 and we want as small an overhang as possible, so I’m thinkjing a finished size of 33 x 49 might work.  It will have a tile edge, not wood.  Current top is dinged formica with an oak edge.  My thought was to remove the old top and use a new piece of 3/4 ply and 1/4 hardie, but I’m not sure if that will provide a thick enough top for the edge tile.  Need advice on the best way to do the edge.
I’m sorry, I thought you wanted it done the right way.
  1. JTC1 | Jun 16, 2005 03:56pm | #1
    Ed,
    Much depends on the availability of different tile sizes / shapes.
    I have no idea what they are called but I have seen and used tiles which turned a 90 to lap an edge or corner.  Conter top thickness at the edge becomes a function of the tile being used.
    I have also used ripped bullnoses on edges.  Tile saw with a site built fixture for repetitive cuts is a big plus.  Apply Hardie on edge and tile just like it was a wall.
    The 1" counter thickness can easily be built up at the edges by laminating another layer of plywood to the underside of the main counter.
    If you build up the edge area, also build up any other areas which have a place to bear on a cabinet edge.  Tile is relatively heavy so the more support you can get in mid-span, the better.
    Jim
    1. ChemicalLew | Jun 17, 2005 01:49am | #7
      I used 4" handmade tile from Mexico to do our last kitchen. The bullnose or V - whatever you cann the L-shaped piece that you install around the perimeter - can be mitered as you say if that style tile does not come with pieces designed for corners. I would caution however, that the miter will result in a sharp edge and care should be taken when setting those pieces to keep from having a dangerous corner. I did not do this in our last house. Fortunately no one was ever cut, but I ran my hand across it often to remind myself to never do that again.
  2. piko | Jun 16, 2005 04:20pm | #2
    1-1/2" for an edge looks more robust, and we're used to it, so you might want to make up the total thickness to that...jtc1 suggests adding add'l material to the u/s, but this might interfere with drawers and doors.
    you might want to look at a new stainproof grout, too -
    http://www.trafficmasterstainproofgrout.com recently reviewed in FHB
    cheers
    ***I'm a contractor - but I'm trying to go straight!***
    1. JTC1 | Jun 17, 2005 12:19am | #6
      As usual, my explanation for building up the edge thickness was as clear as mud.
      I picture frame the underside of the countertop, usually using strips about 6" wide for this purpose.
      The material added to the underside of the counter top edge will rest on the top of the cabinets when installed -- no door / drawer interference as bottom face of counter is even with, and is supported by, the top of the cabinets.
      This raises the entire counter by some dimension ( 3/4" or whatever thickness is added), hence the comment to add same material at other bearing points which were "lost" by raising the edges.
      Doubling the entire thickness works too, but in this case will requires an extra sheet of ply.  Enough 6" strips can be cut from the scrap from his first sheet.
      Jim
    PeterJ | Jun 16, 2005 06:46pm | #3
     Hi Ed
    One thing you might consider which gets overlooked a lot, IMO. If countertop edge projects out farther than vertical plane of cabinet doors, spills drip to floor as opposed to down cabinet face...a good thing.
    PJ
    1. johnharkins | Jun 16, 2005 07:24pm | #4
      I have to relearn nomenclature every time I switch trades but I think what you want are V - caps
      will frame your island beautifully, provide for countertop being proud of most any protuberance ( i. e . overlay doors )
      most v - caps are a thing of beauty and will make a huge difference in your appreciation of islandanother ripping of plywood or 1 x 1" glued and screwed under plywood deck might improve your substrate
      1. FastEddie1 | Jun 16, 2005 11:35pm | #5
        V-caps work well, except when you use natural stone for the counters.  Or when the client selects a tile that doesn't have caps available, and none of those available match the color well enough.
